3D Modeling.
3D Modeling.
After hunting on the internet for awhile I have come up with no easy solution to my problem. I need to taper the top section of many shapes like this for a 3D model for a CNC router to create a carving. What would be the easiest way to go about creating this ideally it'd be like a mountain as a wider base that tapers to a peak in the middle. Any links to videos or commands are very much appreciated. It can start as shown below or just a 2d polyline.
imadHabash
Hi and Welcome to AutoDesk Forum,
PRESSPULL command is your need for such a case,active the command then press inner the shape that you want to extrude.read HERE for more info and you can found a lot of tutorials through Google search.
Imad Habash
swieciakpawel
Hey,
Unfortunately, everything depends on the shape itself.
A) For some simple cases it might be possible to use EXTRUDE with Taper angle (Example), but for many cases this will throw out lot of errors like "Surface is illegal" or "self intersecting body".
Other approaches that You can try are crude ( nothing will look perfect in my opinion), but You might give them a shot if no one comes up with better solution.
B)
If You're interested in just a small taper angle, sometimes it's possible to use something like this:
1. Start with Your 2D Polyline
2. Use command OFFSET (or manually create internal object), that would create second polyline inside
3. Move second polyline upwards
4. Use LOFT command on those polylines to create a solid.
C)
Other thing You might try (If You can accept limitation in taper control) is creating 2 or more extrudes along different directions and then using INTERSECT command to obtain single shape. The more complicated shape, the more directions you have to consider for it to look good. (EXAMPLE).
Good luck!
Kind Regards,
Pawel
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
