3D Model Physical Properties Exploding
Current Version of Autodesk AutoCAD 2015
While doing some 3D modeling I ran into an issue when opening saved models. It appears that my model has exploded the physical properties of objects and their handles. In this particular case flanges and pipe nozzles appear in a separate place than their handles. These objects were grouped with a few other objects and should remain relative to the position of a still I am designing. The "explosion" of physical properties doesn't seem to happen until I try a command or zoom in, almost as if the model is regenerating with commands. I am able to move the object into the correct position although when this is done the handles move as well. Also when this is done it seems to cause more objects to explode from their handles. Initially I thought the file had been corrupted during saving and proceeded to redraw the objects. Unfortunately this has not been a one time occurrence and multiple models have began to show similar malfunctions. This is causing me a great deal of frustration due to the always prevalent time constraints when designing models. Has anyone experienced this and is there a reasonable solution? Any and all help is appreciated. Below is a screenshot of objects exploded from their handles for clarity on the problem I'm seeing.
