AutoCAD Forum
3D model does not unfold correctly
1 REPLY 1
314 Views, 1 Reply
I have a 3D model that will not unfold correctly in Fusion. I unfortunately do not use AutoCAD that often that I can figure this out. The model has multiple bends of 90 degrees and two of 44 degrees. It is the bends of 44 degrees that will not unfold correctly, one is not recognized (it seems) as a bend and the other bends 134 degrees which completely deforms the solid.
Attached is the dwf file of my model.
Any help would be much appreciated!
Niels
Labels (2)
1 REPLY 1
coffeejeanpaul
Hi
It is a bit difficult to say in autocad as your dwg is one solid see image below.
Might be good to direct the question in the Fusion forum or even the inventor.
As Autocad not that I know of has an unfold command, sorry sir.
Forma Design Contest
