Anuncios
3D ghost elements
jim78b
3D ghost elements
jim78b
Hello i have autocad 2025, after working in 3d and refedit a block (i attached the file) autocad give me ghost elements, unselectables!
0 Me gusta
Responder
Soluciones aceptadas (2)
1.428 Vistas
22 Respuestas
Respuestas (22)
tramber
  • Send the AUDIT (_AUDIT) command. With a Yes to the question.
  • Or maybe a ZOOM -> ALL and, then, a ZOOM -> Previous
IF not a setting of Graphic Card, It is what I do in case of problems.
0 Me gusta
Valentin-WSP
@jim78b ,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
jim78b
i tried but not work. the ghost elements are visible, they vanished if i close drawing and reopen it.
i know that i turn off hardwar accelaration i don't see anymore these ghost objects but i need hardware acceleration! i have nvidia quadro p2000.
0 Me gusta
jim78b
is a bug, How can I report this to Autodesk? Since I have an educational license I can't write to them
0 Me gusta
jim78b
I have quadro nvidia p2000  i install latest driver . I see that certified drivers are old in the Autodesk list of supporter certified hardware. What drivers shall i have install ? The latest or the oldest?
0 Me gusta
Valentin-WSP
@jim78b ,
Emilio Valentin
0 Me gusta
jim78b
I have educational license,
0 Me gusta
vinodkl
Hello @jim78b
Type in the command "GFXDX12", set it to "0" and see if that helps.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
jim78b
YES HELPS thanks, but I lose the benefit of fast shaded mode, with the models I have in 3d it's very slow
0 Me gusta
TheCADnoob
0 Me gusta
jim78b
i installed latest nvidia drivers but as I asked do I have to install an old certified driver?
I can remove hardware acceleration but is nonsense because i need all the power of my certified nvidia quadro p2000 card!
Audit, recover purge regapp all!
0 Me gusta
TheCADnoob
If you want to try to trouble shoot the issue, I would suggest trying installing an older driver and see if it makes a difference, though its not a surefire solution. In my experience upgrading the driver usually solves the issues.
If turning off hardware acceleration and/or toggeling GFXDX12 helps, I would recommend doing so.
I get the frustration of hardware not working at peak performance, but there are a lot of variables that have to be chased to nail down the exact issue. Depending on whats going on, that's not always the optimal solution.
CADnoob
0 Me gusta
jim78b
Ok i will try the old driver or wait for autocad or nvidia upgrade
0 Me gusta
jorge_lopez_adsk
REGEN3 should solve the issue without needing to disable fast shaded mode or close/open the DWG. That however sounds like a bug. Please report it so we can fix it.
What are the steps to repro?
Jorge
Jorge Lopez
Distinguished Engineer
jim78b
I used regen3 not work. I a nested 3d block...make refedit and discarge tour see the ghost element if you move block. I can not tell autocad that is a bug because i have a educational version
0 Me gusta
pendean
Community Legend
Community Legend
Then you need to find and install different drivers for your video card: newer or older, you'll have to experiment and restart your PC in between these installs.
Show us screenshots of both tabs of your GRAPHICSCONFIG command pop-up please.
In the meantime... instead of turning off GFXDX12... Have you installed the 2025.1.1 Update yet? ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards please.
If that did not help...  then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices. and uncheck or change one or more of these
Remember, you have a deficient video card / driver, the program can only work around that so much.
Best of luck.
0 Me gusta
jim78b
THANKS I did everything you wrote but the bug remains. installed the update you said.
0 Me gusta
jim78b
Hi. Today i installed certified nvidia quadro p2000 drivers but the bug Remain again.
0 Me gusta
jorge_lopez_adsk
Hi Jim,
I followed your steps and reproduced the issue; also confirmed it is not fixed by REGEN3. I will log a defect. Sorry about the inconvenience.
Jorge
Jorge Lopez
