3D Dwg into AR platform
I am trying to choose the correct product that would take a 3D Dwg and place it into an AR environment.
* I want to place a 3D model onto a printed paper plan using Augmented Reality. When i place the paper print on the table or wall, i want to be able to view my model at scale in a specific position on the plan. Then be able to either walk around the paper print or move the paper print and the model will stay in position*
Can this be done using ACAD?
Can this bee done using Fusion?
Thankyou for your time
Alfred.NESWADBA
Which devices do you have ... and which software for that device(s)?
You can create geometry with that software, but none of them have a direct interface to AR devices.
You need to create the geometry and then transfer that to your AR software/devices.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thankyou for responding
I am using ACAD 2020 and would like to view the AR using both Android and Mac OSx devices.
My research shows that (I believe) Autodesk have an app ENTiTi AR/VR Exporter for Autodesk(r) Fusion 360(tm)
Can I transfer a 3D Dwg to Fusion 360 and then use the ENTiTi app to create my AR?
I would like to be sure before I go ahead and purchase Fusion 360 and find that importing from ACAD does not work.
steven-g
Download a trial version! besides that I believe Fusion 360 is free for hobbyists.
