Announcements
3d Clip and grips.
Shneuph
3d Clip and grips.
Shneuph
When I use the 3d Clip command in a modelspace viewport I can't use grips.  If I select an object the grips appear.  But I can not select the grip to manipulate anything. Is this normal behavior?  It's not something I would guess is by design.  I don't think there is anything going on other than the 3D clip.  If I turn clipping off the grips work.  Is there some sort of variable that I need to change?  Based on my experience with CAD this should not be happening and it's not likely something that would be controlled by a variable.
Thanks for any advice or even just confirmation that this is the behavior you see as well.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Replies (23)
Sofia.Xanthopoulou
Hi Shneuph,
if we are talking about the same clipping command...
When you use 3Dclip you only get the clipping planes, in the little dialogbox, to adjust the view - no grips available.
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Shneuph
Yes the 3Dclip command brings up the dialog box where you can turn on front and rear clipping plane and adjust their position.  Then when I close the window and hit <enter> to exit the command the view (in my model space viewport) is 'clipped' how I selected in the 3DCLIP window.  However, with the viewport set like this I can not select an object grip to manipulate objects.
Sofia.Xanthopoulou
I see,
could you please prepare a screencast for me and upload the drawing, so I can reproduce and examine it ?
Thank you
Shneuph
https://knowledge.autodesk.com/community/screencast/52e4228c-1f12-4db4-a566-e11041107e28
Shneuph
Sorry, I forgot to upload the drawing.  But you should be able to see this behavior on any drawing.  I just started one from scratch with only a few 3dSolids and the same behavior exists.
Thanks.
Sofia.Xanthopoulou
@Shneuph, still no drawing here Smiley Wink
I'd prefer to have your data, too and recreate it afterwards with my tools in order to check if it is data or software related.
Thank you
Shneuph
This should be sufficient.
Sofia.Xanthopoulou
Hi @Shneuph,
just checked this issue.
Well the behavior is as you described, but I think this is normal, considering that this model is now "incomplete" a modification should not be allowed. But I will double check with our experts.
Regards
Shneuph
Thank you for checking.  Could you please explain in what way the model is "incomplete" and how/why this would disallow modifications to it?
Sofia.Xanthopoulou
Well... it is clipped...So, not the complete model is calculated anymore - and the rest of the model is just displayed - not calculated.
That's my understanding - I might be mistaken....
But let's wait for a statement of our experts.
Regards
Sofia.Xanthopoulou
Another question @Shneuph,
why do you need this function? What do you want to accomplish? Maybe there is another way....
Regards
Sofia.Xanthopoulou
Hi @Shneuph,
I had some feedback from our experts telling me that this should work - so I went back to your dataset and exported the model with wblock to a clean template.
Well, I don't know if I did it right this time, but I could edit the clipped model.
Would you please do the same and tell me if it makes a difference?
Shneuph
Thanks for sticking with this Sofia.  I WBlocked the model into a new drawings, applied the clip planes and the grips still don't work.
Is this what you did?:
http://autode.sk/29RyrTW
Sofia.Xanthopoulou
Hi @Shneuph,
actually I "wblocked" by selecting objects - not the entire drawing.
And some other question: Has this drawing been saved in 2016 at any time? I just noticed that it said - opening a 2013 drawing.
Keep me updated.
Regards
Sofia.Xanthopoulou
Hi @Shneuph,
have you checked on this again?
Regards
Shneuph
I just wblocked by selecting objects and it did not change the outcome.  As far as I know Drawing Format 2013 is the latest and is what v. 2016 uses still..
Sofia.Xanthopoulou
Of course... my bad - 2013 format is the latest.
I was completely thinking in Versions - just forget it Smiley Frustrated
@Shneuph, I will repeat my steps and capture them in a video - maybe we are not doing the same thing.
Just give me some time...
Sofia.Xanthopoulou
Hi @Shneuph,
this is what I did:
Does this work for you?
Regards
Sofia.Xanthopoulou
Hi @Shneuph,
you never gave me a feedback on the video. Does it work for you?
I'd really like to give all readers the opportunity to benefit from your experience with this case. So, any feedback will be appreciated Smiley Happy
Thank you
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
