3D Box Command
3D Box Command
3D Box Command
The box command in 3D modeling work space is making me insert an angle when I tab over. The box command normally lets you insert two lengths but now its a length and an angle. its not something with the drawing its with the autocad and its happened on two computers I've worked on so far and with some of my friends that are using it.
Alfred.NESWADBA
can you please press <F2> and show us then this screenshot?
Also maybe you have dynamic input ON but you are used to having it OFF (<F12>) ... or object snap tracking (<F11>)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
would you please try to check some settings from DSETTINGS command ( Polar Tracking / Dynamic Input ) tabs.
Imad Habash
Here is new screen shot
Alfred.NESWADBA
Thank you, but that does not show the command line content.
That is what I wanted to point out (besides of turning off dynamic input as already suggested in my first post):
- alfred -
Alfred NESWADBA
i checked and turned on dimension input where possible and it worked!
thanks so much!
imadHabash
glad to hear that ... 🙂
Good Luck..
Imad Habash
