>> I did most of the drawing on a 2017 version but was working on 2015.
For VIEWBASE objects it sometimes is critical to open drawings with older releases than the VIEWBASE objects are created. That should be avoided.
Just tried: created VIEWBASE with AutoCAD 2018, saved the drawing in 2013 format, opened it with AutoCAD 2017, tried to section the viewbase-object and landed in the MOVE command to.
But in the command line AutoCAD reports that:
Unable to perform the requested action. This drawing was last edited with model documentation in a newer version of AutoCAD.
So it's simply not the recommended way.
>> I am downloading 2018 now and that should, hopefully, solve my problems
Be careful!
- AutoCAD 2018 has a different dwg-format, that files can't be opened in older versions of AutoCAD directly.
- Saving back 2018 drawings to DWG-2013 format even creates more conflicts.
- Mixed environments (different AutoCAD releases) is more difficult with 2018 than with older releases.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
