3D base not working
3D base not working
No aplicable
When I select "base" "from modelspace" from the top banner the command line reads "move". I have no idea what to try. Any ideas?
0 Me gusta
Responder
Soluciones aceptadas (1)
1.104 Vistas
5 Respuestas
Respuestas (5)
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Which version of AutoCAD?
First make sure your AutoCAD has installed the latest update/service pack from >>>here<<<.
If I'm correct that your command-line tells you "Inventor Server failed to load" then this might help >>>click<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
I did most of the drawing on a 2017 version but was working on 2015. I am downloading 2018 now and that should, hopefully, solve my problems.
Best,
Nate White
Lecturer in Technical Direction
Department of Theater and Film
CPA 1042A
419.530.4557
0 Me gusta
Alfred.NESWADBA
For VIEWBASE objects it sometimes is critical to open drawings with older releases than the VIEWBASE objects are created. That should be avoided.
Just tried: created VIEWBASE with AutoCAD 2018, saved the drawing in 2013 format, opened it with AutoCAD 2017, tried to section the viewbase-object and landed in the MOVE command to.
But in the command line AutoCAD reports that:
Unable to perform the requested action. This drawing was last edited with model documentation in a newer version of AutoCAD.
So it's simply not the recommended way.
Be careful!
  • AutoCAD 2018 has a different dwg-format, that files can't be opened in older versions of AutoCAD directly.
  • Saving back 2018 drawings to DWG-2013 format even creates more conflicts.
  • Mixed environments (different AutoCAD releases) is more difficult with 2018 than with older releases.
- alfred -
Alfred NESWADBA
0 Me gusta
john.vellek
Solución aceptada
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Typically, you are not going to be able to open and use a Viewbase Layout that was created in a newer release. Even if the file format is the same version, the Inventor engine associated with each version of AutoCAD changes and are not backward compatible.
So, only go to the newest version if that is where the data will remain.
Please let me know if you have additional questions on this issue.
John Vellek
0 Me gusta
john.vellek
HI @Anonymous,
I am checking back to see if my post or @Alfred.NESWADBA's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
