3-D Object Snap Size
m_angel_lopez94
Message 1 of 8
m_angel_lopez94
So I'm having an issue where my 3-D Object Snaps in a particular drawing is displayed as much larger than normal (it seems to me like it's a line weight issue with the snap?)
The interesting thing is that this only happens on a particular drawing, any ideas?
Pictures of the issue and what I'm used to seeing attached.Issue.pngTypical.png
Replies (7)
Message 2 of 8
Alfred.NESWADBA
from the screenshot I don't know what you mean,
Then it might help to upload this drawing, so we can test with that specific data and environment.
A global solution for issues of one drawing is sometimes to use copy and paste to copy your geometry from modelspace into a new drawing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
m_angel_lopez94
The file is attached, as far as circumventing the problem goes, copying and pasting the data works. However, I can't seem to find what the issue is and therefore can't fix it in the future. I've attached the DWG.
The problem only occurs when dimensioning 3D objects in Paper Space
- alfred -
Message 4 of 8
john.vellek
Hi @m_angel_lopez94,
I am unable to duplicate the problem but I did notice that Audit found a couple of bad objects, purge did a bunch and a -purge>regapps also removed 11 apps.  Perhaps this will help.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 5 of 8
Alfred.NESWADBA
well, I can reproduce the issue, but only in 2016, the same drawing opened in 2017 does not show the same defect.
So I guess it is something special to the combination your DWG and AutoCAD 2016.
As the issue does not appear in 2016 I assume that you will not find a variable to control this behavior, the only thing I have found is to turn off the lineweight (LWDISPLAY) which shows then the 3D-ObjectSnap as thin symbol and not that thick.
HTH, - alfred -
Alfred NESWADBA
Message 6 of 8
john.vellek
I am glad to see that Alfred.NESWADBA was able to duplicate the problem.
Are either of you able to duplicate it using the cleaned file I provided?
John Vellek
Message 7 of 8
Alfred.NESWADBA
Yes, using AutoCAD 2016 I can reproduce the behavior with your file.
Please find the attached video which shows the settings, and the dependency of LWDISPLAY.
- alfred -
Alfred NESWADBA
Message 8 of 8
m_angel_lopez94
Thank you Alfred.NESWADBA, this solved the problem without having to migrate my geometry to a separate file.
As far as the cleaned file John.vellek i was still able to reproduce the issue.
Thank you both again!
- alfred -
