The general strategy to create the heat map you seek using AutoCAD is to:
- Add a Z coordinate to your "point" data.
- Create a surface from the point data.
- Apply a blue to red gradient map material to the surface making sure that the plane for the material map is oriented veritcally and it is scale so that its blue end is at the bottom z coordinate of the surface and it red end at the top.
I created points from your data and then made their z coordinate equal to the text value (temperature?). The resulting relative displacements of the points in Z are much less than the X and Y separation so for better clarity I created a block of the points, scaled it by 1 in X and Y but 1000 in Z and exploded the block.
3Dface objects were then added to create a surface. This is a relatively fast process to do manualy.
I wanted a single object for the surface to apply the material to so I converted the collection of 3dfaces to planar surfaces with planesurf. Union was then used to make a single object from the planar surfaces.
A material was defined from a blue to red graient map I create in Power Point.
The materail was then applied to the surface. The user interface in AutoCAD for adjusting the size, orientation, and location of the mapping gizmo is AWFUL!!! I was able to get the gizmo close to the correct size and orietation. In the following image you can see the planar material mapping gizmo and the 3D surface. I used the box to help me scale and located the gizmo.
Here's a top view, the 2D hheat map I think you want. I am not sure what is causing the red spot.
Once you have a 3D surface model you can use section to create contour lines. I created a few as you can see here.
The above process was done entirely within plain AutoCAD. CReating a surface fro point is easier with Civle 3D and material mapping is much easier with 3ds Max. I'm sure that there are other programs that wuld simplify this process.
lee.minardi
