I am trying to get a 2D view of piping given to me in 2012-ish. Im trying to use flatshot command but i keep getting the error of "There are no solids or surfaces that can be projected." My piping is definitely 3D, but i dont know if its a solid or mesh, or what it is. More than willing to upload a drawing if needed. Any other commands or hints or tips I could try?
Solved by Tomislav.Golubovic. Go to Solution.
Attach sample file.
It looks like your pipes are probably proxy entities, created with some other software (or other version/vertical of autocad, but I'm leaning toward another software entirely).
It was created with Bentley proxy objects, so I'd say it was done with AutoPlant. I'm have a look at it but I can't see a way to get them to flatten, you'd have to get someone with AutoPlant to have a crack at it, otherwise just leave it as a 3D model and create Paperspace Viewports for each of the views you want.
so how do you see it was created with bentley? and how did you see it was a proxy?
I have pdf's, and for construction this was great, im in the process of getting these drawings in to a maintenance drawing for a large plant. I dont have the access to the bentley files or to get anyone to rework it, it may just have to be a redraw if there is no way to flatten.
Thanks for your help.
