2021 Table Break Format Issue
jstanke
jstanke
I have a table created from Datalink / Excel. I break table to fit on the sheet. The new 2nd table is formatted different than 1st column. I am good, but not that good.   HELP!!?!??!?!??
Thanks in Advance!!!
[The image was embedded in the post for clarity by cheryl.buck]
cheryl.buck
Autodesk Support
Autodesk Support
Hi @jstanke,
That is very interesting. I am not able to reproduce the issue when I change the formatting in the table then split the rows. It looks like the cells were filled from a datalink rather than copying the data into the table. Can you confirm that?
I suppose it is possible that the AutoCAD table has different alignment settings than the Excel table and it is acting as an override. If you run a REGEN or REGENALL, does that make a difference?
I would be happy to take a look at the files if you would like. Let me know what version of Windows and Excel you are using.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
jstanke
The table is filled with 'datalinked' info. I could not repair the issue, so i exploded the table, printed / exported what i needed, and "undid" to relink the datalink. Not a fix, but a work around. Good enough to get the job out the door...
Thank you for replying @cheryl.buck !!!!!
cheryl.buck
Autodesk Support
Autodesk Support
Hi @jstanke,
Thank you for the reply. That is really strange, I am glad to hear you found a workaround. If it happens again, let us know, and we can look into it further.
All the best,
Cheryl Buck
shahryar.hedayat
Community Visitor
Community Visitor
Hi All,
The issue is still there. If anybody finds the right solution.
Please share.
Thanks.
Shahryar
