2020 Ribbon Button Clicks are.....unrewarding.
mellishmcw
mellishmcw
Clicking on tools in the ribbon, or for an example, the Linear Dimension tool in the tool ribbon is unrewarding. It turns dark when you run the mouse over it, then upon click, it just doesn't move, dance, lighten, darken....anything. When clicking on the tool palette at least a tool will lighten for a quick moment to signify that it was selected. https://autode.sk/2U31YzO It seems like the line tool is somewhat darkened but ****. The shades of grey are difficult to perceive.
TheCADnoob
Hmm.. If you switch away from the dark theme does it make a difference?
CADnoob
dgorsman
Given the complaints about too much work being done to make the UI "fancy"... not entirely surprising. Still, not exactly a breaking issue, no?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
mellishmcw
Same thing happens in light color theme.
mellishmcw
I mean, is this the same on everyones or just mine?
If this is global, maybe its unintended?  if its on mine, I may try to reload it?
Whether its breaking or not, I am sure they dont want the product to behave in this manor compared to 2019 where it was a visual click?
TheCADnoob
Unfortunately Im away from a system to be able to duplicate what you are seeing. The video isn't really clear as to whats going on. I would report it so they can examine it. https://forums.autodesk.com/t5/autocad-lt-forum/where-can-i-report-a-bug/m-p/6580314#M144201
CADnoob
mellishmcw
were you able to duplicate it?
