2020 insert block manager/window
AMD-JEC
AMD-JEC
the new insert block manager is a load of crap. i prefer the old way. is there a way to get the old menu back. the new one slows autocad down and is cumbersome.  i want to just insert the block into the drawing not a sub-menu that i then have to select it yet again and slowly. thanks. if it aint broke, dont fix it Autodesk!
Responder
Soluciones aceptadas (1)
1.781 Vistas
3 Respuestas
Respuestas (3)
Beka_Tchigladze
you can always use insert command from insert tab
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
0 Me gusta
Beka_Tchigladze
or use "-INSERT>>ENTER>>"BLOCKNAME"" from command line
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
0 Me gusta
jwhite
Solución aceptada
I modified my acad.pgp file to use classicinsert instead of insert. That's one of the commands I usually run by typing in the shortcut instead of using the ribbon. If you do use the ribbon you can probably customize it to run classicinsert.
