2017 Rendering Crash
AMestern
AMestern
  I am working on a presentation due in a day and attempting to Render in 2017. The file is complex but not any more complex than anything I have done before. The file will not render in 2017, crashes just after the render window opens. I have tried on 2 computers, both Autocad approved builds.
 As per another member of this forum I moved to AutoCad 2016 and was able to set up the lighting and render away.
I know there are other software solutions for rendering but since I will extract construction drawings from my original AutoCad drawing I would rather stay inside one software enviroment.
As a test I took a drawing created in 2016 and rendered it successfully in 2017. So I can render '17 drawings in '16 and  render '16 drawings in '17.
0 Me gusta
Responder
Soluciones aceptadas (1)
2.394 Vistas
6 Respuestas
Respuestas (6)
john.vellek
Solución aceptada
Hi @AMestern,
Strange behavior! Can you attach one drawing of each version so I can try it?  Also, does the AutoCAD 2017 fail if you render on the Cloud?
[Edit] The solutin was to clean up missing "Assets" which included a variety of materials and textures. (Some from SketchUp but we don't know if those were to blame in part). Next @AMestern cleaned up a nested block that had some complicated hatches in it. Once it was removed, rendering happened properly
John Vellek
AMestern
John: I have sent a couple of dropbox links. The files are quite large didn't know if they would attach, although I am happy to share my messy work.
0 Me gusta
pendean
Community Legend
Community Legend
PC specs are what?
your Video card is what? it's drivers version is what?
Windows version is what?
File size is what?
Rendering include materials and lights? Or just shades?
0 Me gusta
AMestern
PC specs are what?
Computer: I 7-2600 cpu @3.4 ghz, 8gb ram, Windows Enterprise, AMD FirePro V5900 (FireGL V) (autodesk certified)drivers all up to date
Second Machine: MSI GT60 i7-4710  CPU 2.5GHz, 16 GB ram, Windows Enterprise, Nivdia Quadro K2100, (also certified) also up to date drivers
Windows version is what? Enterprise
File size is what?  File size is 8.24G
Rendering include materials and lights? Or just shades?  About 12 materials some custom and some stock and just shades, no lights.
A.
0 Me gusta
Alfred.NESWADBA
>> File size is 8.24G
Filesize 8GB and memory built in your system also 8GB ... that can't work :cara_guiñando_un_ojo:
In case the filesize is 8MB then please upload it if possible so we can check on our systems if we crash too.
Windows 7 Enterprise, or 8 Enterprise, or 8.1... or 10...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
AMestern
I went through the entire drawing piece by piece. I removed all of the materials, exploded all of the blocks.- None of that mattered.
What I found was one object inside the drawing I had imported from a library of objects. It was a 'Picasso painting', it was a 2D object that was a painting made up of a block within a block and several layers of solid and standard ISO hatching. As soon as I deleted the 2D painting from my drawing I was able to render it quickly in 2017. Kudos to John Vellek for stepping me through cleaning up the drawing and looking for a corruption.
Andrew
