Anuncios
2017 LT object snap setting
No aplicable
In my previous version 2011 LT I was able to attach a tool bar with the "object snap settings" to the left side of the drawing area. Example: Mark a line (left click); choose "midpoint" and start a new line from this point. Or rotate the line with "endpoint" as a basepoint. These operations are of course crucial for the drawing work.
I have not managed to make the same arrangement in the 2017 version.
Suggestions?
0 Me gusta
Responder
Soluciones aceptadas (1)
470 Vistas
3 Respuestas
Respuestas (3)
No aplicable
Solución aceptada
Suggestions?
Type in -TOOLBAR (with the dash).  Then enter OBJECT_SNAP, then choose SHOW.
GrantsPirate
You want a tool bar for Osnaps.  If you already have a tool bar showing then right click and chose from the list.  Otherwise go into the CUI, pick current work space, pick customize work space (right hand side), back to left side to Toolbars, expand, pick Osnaps, pick Done on Right side, Apply, and OK.
Probably an easier way but that will get you there.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
0 Me gusta
No aplicable
Thanks - worked swiftly!
0 Me gusta
