Anuncios
2016 Plotting legacy hidden with line weights overriding final image
mark.sim
Community Visitor
mark.sim
Community Visitor
Community Visitor
I have modeled a simple concrete slab in modelspace with a masonry wall sitting directly on top of the slab.
When printing a vport as legacy hidden in paperspace the slab outline prints heavy as required (slab = 0.5 lineweight) & the wall prints light as required (wall = 0.18 lineweight). My issue is when the wall outline is directly over the slab outline, the wall lineweight overrides the thicker slab lineweight below, hence the final output prints a light line. Is there a way to have the slab's thicker line override the wall above using a single vport?
I can print the vport 'as-displayed' & achieve the correct printed lineweights however there are slab thickenings that will appear as solid lines if printed 'as-displayed' & this is not required.
(Attached image shows a plan of a wall over the left side of a slab)
0 Me gusta
Responder
354 Vistas
2 Respuestas
Respuestas (2)
imadHabash
Hi and Welcome to AutoDesk Forum,
what about using several options are available in DRAWORDER command.you may send to back or bring to front the subject you need.
Imad Habash
0 Me gusta
john.vellek
HI @mark.sim,
I agree with @imadHabash that Draworder is probably what you are looking for.
I do wonder though about your slab thickenings not appearing correctly. Are they indicated with a different linetype that is not displaying properly in your viewport?
John Vellek
0 Me gusta
