2 drawings opening when i open 1 not a new drawing
No aplicable
When i open a drawing Autocad will open 2 drawings not a blank one but one that i had drawn before anyone know how this happened and how to fix. It seems to happen on some of my drawing not all of them, like they are linked.
0 Me gusta
Responder
499 Vistas
6 Respuestas
Respuestas (6)
imadHabash
Does this happen when you use OPEN command (Ctrl+O) or when you double click the CAD file? also try these two way and see if it's repeat.
Imad Habash
0 Me gusta
No aplicable
It happens when I double click on file from explorer or from open drawing in autocad it will open a drawing that I had open before somehow they are connected.
Sent from my iPhone
0 Me gusta
john.vellek
Hi @Anonymous,
Does it open the same drawing twice? or are they different drawings?
I would try a Reset Settings to Default to see if that helps.
You might also set a default template for QNEW in OPTIONS.
John Vellek
0 Me gusta
No aplicable
Hi
It opens up a separate drawing but is one that is from another project. Not the same drawing or a blank one.
Sent from my iPhone
0 Me gusta
john.vellek
Hi @Anonymous,
Have you tried the Reset I suggested previously?
Doe this happen when you try to open the same file as last time or is all files that also open a blank one too?
John Vellek
0 Me gusta
jsiegel-vanderweil
Do you already have the program open when you click on the file in explorer?
AutoCAD doesn't always load properly if you force it to open by clicking on a .dwg file...
AutoCAD user since 1988...
0 Me gusta
