Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Views Broken
Views Broken
Hi guys,
When I click the default isometric views it zooms really far out. The drawing I'm working on was once much larger but I scaled it down to like 0.1 of its original size. The views seem to think the objects are the same size as they started. Ive kinda got around this b y creating custom views but when I go to render on the cloud, I just get blank images for any custom view from the south. Im very new to AutoCAD so I'm lost.
Freddie
pendean
Community Legend
Community Legend
Share you actual DWG file please.
@pendean I've attached it now
pendean
Community Legend
Community Legend
Thanks for the file: if you simply use ZOOM's EXTENTS option you will see the problem: you have content/objects far far away from your model location. Views work the same way, they try and touch every single object in your file.
ERASE everything else: start the command, select ALL, then exclude your model that you wish to save.
Thank you, the views inside of the file are fixed, however when I still try to render any view from the south is still grey. Any idea why?
pendean
Community Legend
Community Legend
Your view is too close or in front of something is what it looks in in your images: try to be more deliberate about your viewpoint placement, see if that helps.
maxim_k
Hi @Anonymous
I am afraid that the problem is related to Cloud Render.
I tried to render the view in question in AC 2021 for Windows and got this result:
You may try to recreate view.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
