Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi all,
I can't seem to change a viewport in layout view to show my drawing properly. No matter what I do the page only shows a very zoomed in view or a very zoomed out view. I have tried all menu options witht he word scale in, including the scale list. I have looked in the properties inspector.
Help!
Solved by maxim_k. Go to Solution.
Hi All,
Lately I've been unable to adjust my view port scale even though the view port is unlocked. Also won't allow me to change the model space scale to check annotation text ect. is placed correct.
Any help would be appreciated.
Regards Jess
Hi All,
Regards Jess
Welcome to Autodesk Forums!
Hi Jessica,
I am able to change viewport scale in your drawing from Status Bar and from Properties palette (viewport should be selected).
BTW, when I opened your drawing for the first time, the viewport was locked.
About model space scale - there is no annotative text objects in your drawing, so changing scale in model space does nothing as it should.
Maxim
I have a similar problem, I am unable to change the viewport scale. Even trying to change through the status bar fails as it is non-interactable. To get around the problem created a new file and pasted the drawing. File recover failed to identify any errors in the file. I would like to know how to fix the file as the copy paste may not work in the future.
