Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi all,
I can't seem to change a viewport in layout view to show my drawing properly. No matter what I do the page only shows a very zoomed in view or a very zoomed out view. I have tried all menu options witht he word scale in, including the scale list. I have looked in the properties inspector.
Help!
Solved by maxim_k. Go to Solution.
Yes, you are right, you can change viewport scale from Status Bar:
In order to be able to set scale for viewport (and pan and zoom inside viewport) it should be unlocked (look at lock-unlock icon)
If you want to set scale and see the right contents - at first make some preparations: activate viewport, unlock it (if it is locked), then zoom approximately into area you want to see inside viewport, then select appropriate scale, the fine-tune position with PAN command.
BTW, you can also control viewport scale from Properties palette with Viewport selected:
Maxim
But that is exactly it, I can't pan or otherwise move to the drawing. The drawing is somewhere off the the left and I when I pan it moves the entire page.
It is really strange why you can not navigate inside Viewport after changing scale.
I am able:
1/ double-click inside viewport, zoom approximately to the place I want to show in viewport,
2/ set appropriate scale, for example to 1:2,
3/ fine-tine with PAN the position of drawing elements (plan)
4/ double-click outside viewport (or call PS command) to switch back to Layout (Paper space)
After step 3 you can lock viewport with botton on Status bar without exiting from viewport
Maxim
Hi Maxim
Thank you. I didn't know I needed to double click inside the viewport. How incredibly frustrating. Thanks for helping me as without it I would not have figured that out.
Now I just need a scale;)
Do you mean ZOOM command?
Command: ZOOM Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: 1/100xp Command:
If you will use XP option with numeric scale expression, such as 1/100, than you can set viewport scale to 1:100 as in example above
Maxim
Could someone please help me, when I scale my drawing into 1/2"=1' on a layout viewport, it showing it very small. Not I'm expecting.
I am using mac, this is strange because in my other file, the scaling in viewport works but this one file it doesn't scale appropriately.
I have attached my file, please help solve this issues.
Desiree
Using Page Setup manager edit Page Setup for the Layout as follows:
Maxim
