Utilisation outil rectangle
lau_e
lau_e
Bonjour,
Comme vous pouvez le remarquer dans la video, je n'arrive pas à utiliser l'outils rectangle.
Avez vous une idée du problème?
Merci
Replies (8)
paullimapa
What if you entered the command by typing Rectangle
Paul Li
IT Specialist
@The Office
lau_e
Hi Paul,
It's the same
have a look on the video
paullimapa
I could not tell in the video you actually typed in the command _.Rectangle
What version of AutoCAD are you running?
Does this problem only happen in one dwg or all dwgs?  Have you tried typing other commands like Pline or Line or Polygon?
Havd you tried resetting AutoCAD?
Paul Li
IT Specialist
@The Office
lau_e
I work with Autocad 2024 for MAC
I've try with other dwg, it's the same.
The problem is just with rectangle
paullimapa
Have you tried reset?
Paul Li
IT Specialist
@The Office
lau_e
No. I'm afraid to do that
lau_e
Hi.
I've resetting autocad and now all are ok. thanks a lot
paullimapa
Glad that worked out for you…cheers!!!
Paul Li
IT Specialist
@The Office
