Using Save As
Using Save As
No aplicable
When using Save As command it takes me directly to Applications/A.OCUi.framework
Can anyone give me a reason for this
0 Me gusta
Responder
Soluciones aceptadas (1)
673 Vistas
6 Respuestas
Respuestas (6)
maxim_k
Hi Clive,
Does this happen even you already save drawing in a different location?
If yes - Where do you save your drawing? On local or network drive?
Have you tried to SAVEAS some drawing in the Documents folder on your local drive, then quit AutoCAD with QUIT command, then launch AutoCAD again? What happens now with SAVEAS?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi Maxim
Firstly thank you for your prompt reply
We have followed your suggestion of
/Have you tried to SAVEAS some drawing in the Documents folder on your
again? What happens now with SAVEAS?/
Sadly when using Save As it still sends us down the Acad 2013/ Appl /
Cont / A.OCUi.framework
Any other ideas
Clive
0 Me gusta
maxim_k
What macOS installed on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi Maxam
Mac installed on our machine:    10.13.5
Regards
Clive
0 Me gusta
maxim_k
Solución aceptada
I think that explains everything.
AutoCAD 2013 for Mac (as I see from your previous post - you are using 2013 version) is not compatible with macOS 10.13. The last compatible macOS for AutoCAD 2013 for Mac is 10.10 (Mac OS X Yosemite).
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi Maxim. many thanks for the explanation.
One thing that puzzles me is the Save AS command has only recently shown
these symptoms.
Up to this point it has been OK.
Clive
0 Me gusta
