unable to modify pgp - autocad LT 2016 mac
No aplicable
Dear all,
I wanted to change some shortcuts for some commands, entering the pgp-file, but the changes didn't seem to function.
for example: I changed the shortcut for copy 'CO' into 'Z', but the zoom function still appeared when I entered 'Z' into the command tool.
Now I have the double trouble that I cannot enter the PGP file anymore!
I tried < tools <customize< edit command aliases - or ALIASEDIT in the command
Somebody recognise the problem?
thanks
0 Me gusta
Responder
332 Vistas
3 Respuestas
Respuestas (3)
tramber
Did you remove the Z alias form ZOOM ? I beleive I remember that the last shortcut is the one to be used.
Did you, at least, restart AutoCAD after it is done ?
There must be no reason for the fact that you can't open the pgp file. I'm on PC and can not help.
0 Me gusta
No aplicable
thank you for the respons,
I didn't remove the ZOOM - Z. This could be the solution,
but I'm still dealing with the problem that I can't reopen the PGP.
also I tried to type REINIT in the command bar, to reset what I ve done.
but it doesn't seem to exist on my autocad mac?
0 Me gusta
maxim_k
Hi
Have you tried to find and edit PGP file, as described here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/unable-to-modify-pgp-autocad-lt-2016-mac/m-p/87...
"The default PGP file can also be opened by launching Finder, pressing and holding Option, and clicking Go Library. In the Finder window, navigate to Application Support/Autodesk/Roaming/<product name>/<version>/<language>/Support and double-click acad.pgp (or acadlt.pgp for AutoCAD LT) to edit the file. If prompted for an application to use, select TextEdit."
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
