Anuncios
Unable to extrude from an imported DXF [AutoCAD for Mac]
ndesaraju
Observer
ndesaraju
Observer
Observer
When I attempt to use the EXTRUDE or PRESSPULL commands, they both either don't recognize the lines or throw an error saying "Cannot sweep or extrude an object of this type." The DXF was exported from Inkscape where I drew it as an SVG. I've tried exploding the block into splines as well, but this does not work either. The SVG and .dwg I'm working with are attached.
@ndesaraju
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Unable to extrude from an imported DXF
0 Me gusta
Responder
360 Vistas
3 Respuestas
Respuestas (3)
maxim_k
Hi @ndesaraju ,
I exploded the block in your drawing and used JOIN command to join splines.
Then I was able to use EXTRUDE command - see attached DWG.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
greetings @ndesaraju
You cannot extrude a block. That appears to be your issue. Not much else. See the tips above for how to work with your posted content.
0 Me gusta
alina.balkanskaia
Hello, @ndesaraju! Thank you for posting your question in Autodesk Community!
I see you've got a couple of recommendations. Please, click the "Solution" button for the most helpful answer. So that other users can benefit from this information.
Alina Balkanskaia
0 Me gusta
