Typing only working on Command Line
gilesNXQ3W
Message 1 of 13
gilesNXQ3W
AutoCAD for Mac (2021 and 2022) having the same problem in different computers. It starts working properly, but sundlenly typing anywhere on the screen, or when in a command typing the dimensions, doesn't work and needs to click on the command line to input the typing. Even Escape stop to work and needs to go to the command line, click on it, and press Escape.
I don't know what is going on and it is not something that I could provide a screenshot because it's regarding typing. I am very experienced in AutoCAD (work with it since 2008 on PCs) and have never seen it before.
Replies (12)
Message 2 of 13
maxim_k
Hi @gilesNXQ3W ,
Do you use Dynamic Input? Or it is turned off.
Have you tried:
- restart AutoCAD
- restart your Mac
- reset AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 13
gilesNXQ3W
Thanks for the answer, @maxim_k . I do use Dynamic Input, I will try to turn it off when I get to my computer. But Dynamic Input is really necessary for me. I can't imagine myself working without it.
Message 4 of 13
maxim_k
@gilesNXQ3W ,
You can try to reset AutoCAD, but in this case you will lose all your custom settings.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 13
gilesNXQ3W
None of this worked. =(
Message 6 of 13
pendean
Community Legend
Community Legend
Start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
Message 7 of 13
m_autodeskMVGMK
Community Visitor
Community Visitor
I think I'm having the same problem with Autocad LT for Mac 2021. Did you find a solution? See my screen recording.
Message 8 of 13
gilesNXQ3W
It  seams our problems are differents. The one I was having (and still) is because of Zoom. Whenever we write on the screen while in a Zoom call using it's pen (annotate option) the AutoCAD screen (or any other software you be working in) gets at it was in the background and in order to get control again you need to click on the screen.
Message 9 of 13
maxim_k
Hi @m_autodeskMVGMK ,
If you have macOS Ventura on your mac, you need to install latest Update for  Autocad LT for Mac 2021:
https://help.autodesk.com/view/ACDLTM/2021/ENU/?guid=AUTOCADLT_MAC_2021_3_FIXED_ISSUES
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 13
nathalie
Community Visitor
Community Visitor
Im having the same problem as @gilesNXQ3W , Please help I have restarted and nothing changes.
Message 11 of 13
maxim_k
Hi @nathalie ,
What AutoCAD for Mac version do you use?
What macOS installed on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 13
gilesNXQ3W
Regardless of the version, it has always been happening since I posted it.
But using Sonoma 14.5 and AutoCAD 2024.
Message 13 of 13
maxim_k
Hi @gilesNXQ3W ,
Have you installed the latest Update to AutoCAD 2024 for Mac?
Do you use any third party window manager on Mac?
Do you use external (second) display with AutoCAD for Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
