Anuncios
two finger gesture keeps randomly toggling between zoom and pan. HELP :(
No aplicable
After rolling back from El Cap to Yosemite I had to reinstall autoCAD 2014 along with all 3 SPs. however, the CAD behaves very strange when I switch between 2 opened .dwg files or e.g. one .dwg and an excel file in terms of that it randomly toggles pan and zoom for two finger gesture. Before roll-back and reinstall two finger gesture was ONLY zooming. How can I make it back since MBUTTONPAN and ZOOMWHEEL don't do anything at all.
Thanks in advance.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.735 Vistas
6 Respuestas
Respuestas (6)
No aplicable
anyone?
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
I think you need to try to reset AutoCAD from Application tab of AutoCAD preferences.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
thanks :cara_con_una_leve_sonrisa: but now it just pans. is there any other way to switch this gesture into zoom?
0 Me gusta
maxim_k
Solución aceptada
2-finger dragging gesture is for pan by design.
For zoom you need to use:
Zoom In:
- Pinch open
- Option key + 2-finger drag up
Zoom Out:
- Pinch closed
- Option key + 2-finger drag down
http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Hi.
same problem here AND the suggested solution did not work.
Mac OS X Yosemite 10.10.5
Autocad for Mac J.51.M.453
My settings are now set to default (restarted).
Anu suggestions are heartily welcomed!
0 Me gusta
No aplicable
Hi, same problem here too, but with the Sierra. Has anyone found a solution? I've done all the autocad updates but nothing has changed.
0 Me gusta
