Trim tool problem
sark.asadourian
Observer
Trim tool problem
sark.asadourian
Observer
Observer
I am use 2018 AutoCAD for mac. When I try to trim a line it over shot. Ho can fix this.Screen Shot 2018-12-05 at 10.33.07 AM.png
0 Me gusta
Responder
556 Vistas
5 Respuestas
Respuestas (5)
maxim_k
Welcome to Autodesk Forums!
Hi Sark,
What do you mean by "it over shot"?
On the screenshot you attached I can see only one selected line, but in order to be able to trim an object in AutoCAD you need also to have another objet(s) which acts as cutting edge.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
sark.asadourian
Observer
Observer
The vertical line is my cutting edge. You can see the diagonal line does not the vertical line. This is not what I wanted to happen.
0 Me gusta
sark.asadourian
Observer
Observer
0 Me gusta
pendean
Community Legend
Community Legend
use REGENALL command, does your "blue line" move?
what is the variable EDGEMODE set to?
0 Me gusta
maxim_k
What kind of object is vertical line (cutting edge)?
If it is an arc, or a circle, or spline, or arc segment of polyline, then Dean's advice about REGENALL should work.
Can you share your drawing here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
