Anuncios
Trim Error
Trim Error
No aplicable
when i enter the trim command and double-click it to mane a general selection, it doesn't trim the line intersecting the 2 lines! Instead it partially trims the line.1. As you can see the selected line is a whole1. As you can see the selected line is a whole2. after double clicking- instead of erasing the line till its intersects the vertical line, it only erases half of it2. after double clicking- instead of erasing the line till its intersects the vertical line, it only erases half of it
0 Me gusta
Responder
527 Vistas
1 Respuesta
Respuesta (1)
maxim_k
Welcome to Autodesk Forums!
Hi Jhanvi,
I think the lines in your drawing are not on the same construction plane, plus, view direction is not perpendicular to XY plane of current UCS.
So try to use PLAN command to set view direction perpendicular to XY plane of current UCS:
https://help.autodesk.com/view/ACDMAC/2019/ENU/index.html?guid=GUID-3779DF52-AA24-47D2-B72C-018D4A90...
Then use FLATTEN command (hope you are using 2019 AutoCAD version) to flatten all objects in your drawing:
https://help.autodesk.com/view/ACDMAC/2019/ENU/index.html?guid=GUID-0E2744A7-AAB9-4AE9-9614-5697668C...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
