Anuncios
Triangle tessellation to continuous surface
No aplicable
I got a 100Mb DXF file which seems to be a readapted STL 3D scanning as it is made of tons of small triangles and despite being on a quite new machine, the program frequently freezes.
Is there a way to replace all the triangles with a surface, possibly simplifying the drawing (I only need to split the elevons and modify the front cover of this delta wing plane?
Thank you
0 Me gusta
Responder
Soluciones aceptadas (1)
802 Vistas
7 Respuestas
Respuestas (7)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Hi
If the model consists from 3D Faces , then yes, you can:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Conver...
But keep in mind that such operation can easily overload your Mac, so you can try to do the conversion by small parts.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
thanks the solution is working but it totally freezes the PC even on a small surface. Is thee any way to simply the computational time?
0 Me gusta
maxim_k
Can you share your drawing?
Save it in DWG format, it should become much smaller in size.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
dgorsman
AutoCAD isn't that great at complex surfaces.  You might be better off with Fusion 360 or a full-blown surface sculpting program for most, if not all, of such a process.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
No aplicable
Here is the DWG, as suggested this format saves up a lot of space (21Mb vs 100Mb) but again even small surface union cmd isn't doable using a consumer pc.
0 Me gusta
maxim_k
Hi Giammarco,
I looked at your drawing and realized that @dgorsman was right - it is practically impossible to convert 3d faces that form the model into 3d Solids or Meshes in AutoCAD.
I used Rhinoceros for Mac to convert 3d faces in your drawing to 3D Solids, but at first I reduced meshes by 90% in Rhinoceros.
You can look at the result in attached drawings - Rhino export-solids.dwg - as it was exported from Rhino (solids)
and Rhino export-meshes.dwg - I converted solids, created in Rhino to Meshes to reduce file size.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you very much
Actually that's the only solution as the file is too complex to create a mesh
0 Me gusta
