Transparent Layer in viewport but some of the items in layer not transparent
ginacerv
ginacerv
I am using the student version of AutoCad for Mac 2021.
I have made a layer transparent in a viewport, but 1-2 items in the layer are not showing transparent.  I have checked the layer assigned to the item and it is the same layer.
I also find that if I edit an item at all, the transparency for that item then reverts back to 0 - even though the layer is still set to 90.
Can anyone help me understand why this is happening?
0 Me gusta
Responder
Soluciones aceptadas (1)
438 Vistas
3 Respuestas
Respuestas (3)
maxim_k
Welcome to Autodesk Forums!
Hi @ginacerv ,
I cannot reproduce the issue you described.
Can you share a drawing with the problem?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ericAvB
Solución aceptada
Hi @ginacerv,
Some quick questions:
- Have you also checked the transparency properties of each item specifically? Because you can edit transparency properties individually (set it to by block, by layer or by object). This can interfere with the adjustments you make in Layer Properties;
- Are these items blocks?
- If so, make sure that the entities in the block are placed in layer 0 with transparency properties set to ByLayer;
ginacerv
That worked! Thank you!  Yes the problem children were blocks.
