Anuncios
Transparent Hatching in AutoCAD for Mac
No aplicable
Im creating a solid hatching for a path in a grey and adding a transparency of 80.
when I export it to a pdf it creates lines all over the hatching?
Any ideas?
@Anonymous,
john.vellek has edited your subject line for clarity:Transparent Hatching
0 Me gusta
Responder
Soluciones aceptadas (2)
5.183 Vistas
7 Respuestas
Respuestas (7)
gccdesign
I see it in the PDF, but the dwg would be more helpful to see what's going on.
GChapp
0 Me gusta
pendean
Community Legend
Community Legend
AutOCAD for MAC forum is way over there http://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
Remember to share your DWG file and let them know you are using the MACOSX 10.11.4, the Quatrz drvier and list your AutOCAD/LT version too,
0 Me gusta
john.vellek
Hi @Anonymous,
I am unable to duplicate this situation in a new, clean drawing.Can you tell me the process you are using to create the PDF? Please also attach a sample drawing so I can further assist you.
John Vellek
0 Me gusta
maxim_k
Solución aceptada
It is knowing bug in AutoCAD for Mac (since initial contemporary 2011 version).
The workaround is here:
https://macacad.wordpress.com/2013/04/03/workaround-for-printing-solid-hatches-with-transparency-in-...
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
IHi maxim_k,
I am curious to see if this bug has been fixed. As I mentioned, in AutoCAD 2016 for Mac I created a new solid hatch with 80% transparency and it showed up correctly.
Have you tried this yet? If so, can you attach your drawing for me?  I would like to think this is finally solved :cara_con_una_leve_sonrisa:
John Vellek
maxim_k
Hi John,
The results are in attached PDF file.
AutoCAD 2016 with Update 1 installed.
The bug is still there.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
Solución aceptada
Hi @maxim_k, I stand corrected. The first time I tried to do this it appeared to plot correctly but perhaps when I clicked Plot Transparencies it didn't stay turned on.
What is even more perplexing is that when I opened your sample on the Windows side it too plotted with the lines.
A strange bug that I hope gets remedied. Thanks as always for your contributions.
John Vellek
0 Me gusta
