Total Length in MacOS [AutoCAD for MAC]
MPB007
Observer
MPB007
Observer
Observer
Hi, ive got autocad on macOS, ive got a lisp file to select all the lines to give me the total measurements in millimetres, but this wont work on macOS, is there a compatible file that i can use to do this because the measurgeom option on autocad takes to long to do all designs by just selecting them
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Total Length in MacOS
0 Me gusta
Responder
Soluciones aceptadas (2)
7.579 Vistas
23 Respuestas
Respuestas (23)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Hi Marius,
Try attached tlen.lsp which:
"Calculates and reports the total length of a selection set of line, polyline, arc, circle, ellipse, and other objects in drawing."
It works fine on my Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Hello, please can you mention in which folder should we Paste the tlen.lsp file?
0 Me gusta
maxim_k
Hi Charles,
You can place LSP file to any folder inside your Home folder.
I'd recommend you to create special folder for such cases and add it to TRUSTEDPATH system variable:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2017/E...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hello Maxim,
Please help me.
I have pasted the tlen.lsp in the ApplicationAddins folder of ACADLT 2019 but the command tlen is does not working.
I have to measure a total lenght of 2021 pipelines and I am desperate!
May you help me please to understand how to do this?
Many thanks in advance
Andrei Vrublevschi
Beginner in ACAD business
0 Me gusta
maxim_k
Solución aceptada
Hi Andrei,
Sorry, but AutoCAD LT doesn't support AutoLISP (that is one of the reasons it is cheaper than full AutoCAD).
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Hi Maxim,
Thank you very much for your quick reply.
So, to be clear for me, have I  any chance to calculate a total lenght with ACAD LT ?
Andrei
0 Me gusta
maxim_k
Well, also AutoCAD LT "LT is the wrong software for what you need to do", if you have Excel on your Mac, you can try the solution from this thread:
https://forums.autodesk.com/t5/autocad-lt-forum/how-to-measure-total-length/td-p/6317587
To be more precisely, you need Total length.xls spreadsheet from this post:
https://forums.autodesk.com/t5/autocad-lt-forum/how-to-measure-total-length/m-p/7160235#M155052
You also need to make some preparations in AutoCAD LT - enable LOG file for the time you will collect data for calculations - results of LIST command. So at first you need to verify (or change) the location of AutoCAD LOG file in AutoCAD preferences -> Application tab ->Log file location:2019-04-08_16-37-02.png
Then you need to turn on LOG file creation with LOGFILEON command.
From now all Command prompt output will be written to XXX.log file (XXX - the name of current drawing) in the folder you set for Log File Location.
Now you need to set undocumented system variable QAFLAGS=2 - this will allow not to use LIST command without any interaction, until it complete its job.
Now - use QSELECT command to select polylines (or other types of objects you want to calculate total length) in your drawing. After you select all polylines you need (they should be selected) - use LIST command to collect information about them.
If you don't need calculate length anymore, turn off LOG file creation (other way Log File Location folder will be blowed with unnecessary .log files)
Open "XXX.log" file created for your drawing in plain text editor (Textedit app), you will see something like this:
Command: LOGFILEON
Command: QSELECT
Select objects: Specify opposite corner: 4645 found
Select objects:
4157 item(s) selected.
Command: LI
LIST 4157 found
                  LWPOLYLINE  Layer: "AXIS"
                            Space: Model space
                   Handle = 15d968
              Open
    Constant width    0.0000
              area   0.0000
            length   2518.8764
          at point  X=204049.8573  Y=73259.8524  Z=   0.0000
          at point  X=204049.8573  Y=70740.9761  Z=   0.0000
                            Space: Model space
                   Handle = 15d964
              Open
              area   0.0000
            length   2518.8764
          at point  X=197483.6713  Y=73259.8524  Z=   0.0000
          at point  X=197483.6713  Y=70740.9761  Z=   0.0000
                 LWPOLYLINE  Layer: "WIN"
                            Space: Model space
                   Handle = 15c73c
            Closed
              area   146763.8186
         perimeter   1606.5530
          at point  X=201932.3048  Y=76774.7109  Z=   0.0000
          at point  X=202150.3897  Y=76390.8032  Z=   0.0000
          at point  X=202484.3305  Y=76394.3305  Z=   0.0000
          at point  X=202358.4077  Y=76779.1939  Z=   0.0000
                            Space: Model space
                   Handle = 15c73b
              Open
              area   0.0000
            length   415.1461
          at point  X=190108.7357  Y=76711.6982  Z=   0.0000
          at point  X=190206.1890  Y=76308.1525  Z=   0.0000
Command:
Now select everything from the beginning of LIST command to its end and copy to clipboard.
Open Total length.xls in Excel and allow macros in it.
Use  the button labelled 'paste & calculate'. The object properties text will be pasted into column A and the formula in column B will analyse the text & extract the relevant length data. The total length will then be displayed in the green result box in your chosen format. (full description of how it works in spreadsheet - see in the post I linked above)
That is all.
Once again - don't forget to switch off creation of LOG file + set QAFLAGS=0 (default value) after you will make all calculations.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Hi Maxim, Many many thanks! Good day, Andrei
0 Me gusta
maxim_k
Hi Andrei,
Have you tried the trick with Excel? Does it work for you?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Добрый день.
Спасибо за вашу работу!
Есть проблемка с  Tlen.lsp
Я загрузил его через команду appload, он вроде успешно загрузился, но не работает.
0 Me gusta
maxim_k
Добро пожаловать на Форум!
Здравствуйте, Антон!
Что Вы видите в командной строке, когда пытаетесь выполнить команду?
Не работает во всех файлах чертежей? Даже во вновь созданных, с небольшим количеством объектов?
Если только в определенных - прикрепите пример DWG файла где Лисп не работает, я попробую разобраться в чем дело.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Добрый день, Максим.
В командной строке прописано, что файл успешно загружен.
Пробовал на разных файлах, не работает.
При вводе команды applad, в всплывающем окне лисп прописан но не активен (скинул скрин)
Я все делал, как для автокада под виндоус. Тоже кастати ваш лисп загружал - все работало
Спасибо!
0 Me gusta
maxim_k
У меня все работает с Вашим файлом:
Вы точно загружаете необходимый LSP?
На вкладке "Loaded applications" он и должен быть неактивным, поскольку эта вкладка предназначена для выгрузки (unload) приложений из памяти, а приложения AutoLISP выгрузить командой нельзя - они выгружаются автоматически при закрытии файла, в котором были загружены (если только они не прописаны в Startup Suite)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
спасибо!! все работает. Это я лошарик)
0 Me gusta
djunira2014
Community Visitor
Community Visitor
should we load the plugin every time we want to use it? or we load it once?thanks
0 Me gusta
maxim_k
Hi @djunira2014
Yes, you need to load it every time, but you can ad it to Startup Suite in APPLOAD window and it will be loaded automatically:
http://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-B38F610B-51FB-4938-BDEC-A0A737F5DB6C
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
djunira2014
Community Visitor
Community Visitor
Thanks.
0 Me gusta
cmeddock
@AnonymousI'm 4 years late, but was looking at this thread trying to solve a similar issue. I also have LT, plus I'm a novice at computer science, so the solution will take too much brain power for me. However, I have a painstaking work around for others who come across this thread; it may be helpful. Can you connect all the segments of your pipeline into 1 single polyline? Then select the polyline and see the total length in the properties window?
0 Me gusta
ruirego
hello,
im also novice here trying to improve my productivity with the few knowledge that i have.
for that exemple, if you have plines instead of lines you can automatically sum all (even if not connected)
hope it helps
r^2
0 Me gusta
