Total Length in AutoCAD LT for Mac
ruirego
Message 1 of 12
ruirego
hello Maxim,
this is a brutal solution for the total lenght of polylines in Autocad LT Mac.
for a long time i looked for a solution...
i just wonder, if there is any update for nowadays (2022/11). is there a way to sum the lengths separate for each layer?
thanks,
R^2
This message was removed from the topic https://forums.autodesk.com/t5/autocad-for-mac-forum/total-length-in-macos-autocad-for-mac/td-p/8034... into a separate question by @alina.balkanskaia
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
@ruirego As an Lt user, you do not get any customized niceties like LISP that would solve your needs and present it in an easy to use manner. That's by design for your low-cost LT version of AutoCAD for MAC.
In LT, you only have access to core commands and no conveniences. PROPERTIES and LENGTHEN commands are worth exploring, after you isolate your needed layer first of course.
Post back if you get stuck.
Message 3 of 12
maxim_k
Hi @ruirego ,
No, LT is still LT - you cannot use AutoLISP in it.
You can add Layer as additional condition when you use QSELECT command:
Now all polylines on Layer 0 will be selected.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 12
ruirego
hello Maxin,
i meant updates in the excel sheet!
i have tried quick select as you suggest, but i have several different layers.
I'm not great in excel but I have made some adjustments in the sheet that can give me the total length by layer (see attachment). Somebody better in excel can make the sheet better.
Message 5 of 12
ruirego
hello Pendean,
i used PROPERTIES in the "old way". it was a nightmare...
to get the total length of the polylines, i had to click one by one and see the length in the properties, then i had to sum all polylines lengths for each layer.
about LENGTHEN, how can it help me?
(note: I'm working on electricity, electricity and telecommunications projects. Each layer is a type of cable.)
Message 6 of 12
pendean
Community Legend
Community Legend
@ruirego LENGTHEN command, at the commandline, lists the total length of every PLINE you select when prompted to do so. One By One. A limitation of your chosen low-cost LT version of AutoCAD.
Did you try the QSELECT method suggested above yet https://forums.autodesk.com/t5/autocad-for-mac-forum/total-length-in-macos/m-p/11530737#M44453
Message 7 of 12
ruirego
Hi pendan
is LENGTHEN a only windows feature?
the QSELECT if very manual, i'm using the method in the other post (QSELECT-LOG-EXCEL)
R^2
Message 8 of 12
maxim_k
Hi @ruirego ,
LENGTHEN is available in AutoCAD for Mac too.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 12
ruirego
I don't understand how can we measure the total length of polylines with LENGTHEN
in the help it says "Changes the length of objects"
r^2
Message 10 of 12
pendean
Community Legend
Community Legend
@ruirego You glossed over the first line in my post I suspect https://forums.autodesk.com/t5/autocad-for-mac-forum/total-length-in-macos/m-p/11535792#M44474
Wondering if you tried it while staring at the expanded commandline: LENGTHEN at the lists the length of every object as it is selected. It does not "total" anything, you are still in LT, handcuffed aka hobbled by not being able to do much beyond the very basics aka the long way.
HTH
Message 11 of 12
alina.balkanskaia
Hello, @ruirego! I removed your discussion from the previous topic because you are looking for a new Solution. I see you have a lot of helpful information from experts. I hope you can inform us when you will find the Solution!
Alina Balkanskaia
Message 12 of 12
ruirego
ok for me...
but, as i mentioned before, i have found a solution with the excel sheet.
r^2
