AutoCAD for Mac Forum
Welcome to Autodeskā€™s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Tool and menu bar missing in autocad2011 mac
29 REPLIES 29
Message 1 of 30
6375 Views, 29 Replies
I have downloaded Autocad 2011 mac (Student version) yesterday and it installed it on my Macbook pro 15" (Core i5, 4Gb RAM and NVIDIA GeForce GT 330M) but der is this problem, it does not any menu and even no tools I have also attached Screenshot of my autocad...... please help me.....
29 REPLIES 29
Message 21 of 30
pavanjella
in reply to: david.lau
Hi All,
Please apply AutoCAD 2011 for Mac Update1:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16105699&linkID=15839491
This should fix the issue you are seeing with missing tools/icons.
Please reply either way whether it works or not.
thanks,
Pavan Jella
AutoCAD Test Developement
Autodesk Inc
Message 22 of 30
in reply to: pavanjella
hi thanks for your help but no it didnot work for me .im still using my pc for autocad . to bad.
Message 23 of 30
in reply to: geoffreymbrown
I Tried all the solutions above but I still don't get my Toolset pallet.
Another solution?
Thx
Message 24 of 30
Still doesn't work on my mac!
Thx for searching a solution
Jens,
Belgium
Message 25 of 30
david.lau
Can you double check the workflow posted by me?  I have done a remoted desktop session and it definitely worked for me.   Can you send us a  screen capture of your problem?
David Lau
Message 26 of 30
In attachment a picture of my terminal. I typed "apllications" and it didn't work so I tried it in my own laguage and it also didn't work. Second attachment is my Autocad screen. Ik can switch on or of all my pallettes exept my toolsetpallet. It's crossed on but it doesn't show.
Thx for the support
Message 27 of 30
moe29
djenzz
you're missing a space
add a space after ./copyreg.sh and before /Programmas
Message 28 of 30
in reply to: moe29
It didn't worked also. But now I Reinstalled Autocad and when I typed TOOLSETS it directly showed so my problem is solved.
Thx to all!
Greetings
Jens Vanhecke
Belgium
Message 29 of 30
I had the same problem! After reinstall on my Mac, acad is running with toolset.
Maybe a dutch version problem?
Tags (1)
Message 30 of 30
steve.j.jinks
I had this problem too.
I actually tried the recommended fix from this discussion a couple of times (for accuracy). Which didn't work.
Redownloaded and installed which took some time, but worked.
NOTE: If you are reinstalling, remember to click the DELETE AutoCAD preferences button. It is necessary to perform the reinstall and fix the problem.
Steve
ā€Boost
