Text not printing in Paper Space
I have an issue printing a few drawings in AutoCAD Electrical 2013 through Paper Space.  The text that doesn't print is attributed text in various 3D blocks.  What bothers me is the blocks print in some instances but not in others.  I use this same array of blocks in an assembly drawing (attached TSI515-014) and everything prints fine.  The difference between the two drawings would be the extra text I add in paper space.  If I preview the plot, everything seems to be there.  If I try and plot to a .pdf file through AutoCAD, it seems to be worse so I'm inclined to think this is an AutoCAD issue and not a printer issue. For reference, the printer I'm using is a Ricoh Aficio MP C4502.  I have attached a scanned version of the printed drawing showing how it looks.  The terminal blocks on the right show the terminal numbers while some of the blocks reading from right to left have their's missing.  Same goes for the rectangular labels above the devices, as you can see, some print while others do not.
Thanks in advance for any help you can offer.
Drew
maxim_k
Welcome to Autodesk Forums!
Hi Drew,
Sorry, but this is AutoCAD for Mac Forum and you asking about AutoCAD Electrical.
So I think it is better to ask your question here:
http://forums.autodesk.com/t5/autocad-electrical-general/bd-p/38
Plus, I think that it would be difficult to answer your question without having at hand your drawing file.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks. I will try other forum.
