Hello Tricia,
I'll try to be brief.
>>>>I need two different types of headers. One at the top and others down the rows but all I seem to be able to do is data cells.
1/ Select table rows you want to make Title (you call it header)
2/ On the Properties Palette select Row Style dropdown
3/ Select Title - you will see the result - all cells in the row are merged now
OR, if I misunderstood you:
Select row you want to make Header and change Row Style to Header on the Properties Palette
>>>>>Also I can't seem to set the indention for it i.e. center, left, right
1/ Select a cell or range of cells
2/ On the Properties Palette select alignment type
>>>>>Also I guess I must set up all of the rows at the beginning otherwise it goes to the right if I stretch it.
With table selected uncheck "Enabled" for Table breaks on the Properties Palette
>>>>> Do I have to set the font every single time I tab to the next cell? I'm wasting lots of time changing the fonts in all of the cells
from the default one.
Select Text Style and other text properties you need for all types of the cells - Data, Header, Tittle:
