Superhatch - unknown lines
Hello! I used the Superhatch command to create a custom hatch for my brick facade, and these random diagonal lines seem to appear along with the hatch, and I can't seem to get rid of them. Does anyone have a solution to this problem?
maxim_k
Welcome to Autodesk Forums!
Hi Sue Yen Chong,
These lines are frames, which AutoCAD uses to show SUPERHATCH objects.
You can turn them off by setting system variable XCLIPFRAME=0
http://help.autodesk.com/view/ACDMAC/2018/ENU/index.html?guid=GUID-DA921BBF-A545-4144-A63D-D866772C3...
The default value of XCLIPFRAME is 2, this allow to show frames in the drawing, but do not print them.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you so much Maxim!
