Suddenly Slow performance when editing a file.
No aplicable
I worked on the draw (11.5M) and suddenly it becomes very slow. I tried to copy to new draw, purge, -purge,recover but nothing helps.
Please help.
Thanks.
0 Me gusta
Responder
Soluciones aceptadas (1)
682 Vistas
9 Respuestas
Respuestas (9)
maxim_k
Hi Marta,
What AutoCAD version do you use?
If it is 2020 or 2021 version, I recommend you to clear all blocks from Recent blocks tab of Blocks palette:
Activate Blocks palette, go to Recent block tab, right-click inside the tab and select "Clear all" from context menu.
Test AutoCAD performance.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
I work with version 2019 for students.
There is no "Blocks palette" there.
0 Me gusta
maxim_k
Do you have slow performance only with one particular drawing?
If so, can you share it here on the Forum?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
It was 11 M and after very small changes became 15M.
I added the file.
Thank you.
0 Me gusta
maxim_k
Solución aceptada
I reviewed your drawing and have fount that there are a lot of parametric constraints in it:
https://help.autodesk.com/view/ACDMAC/2019/ENU/index.html?guid=GUID-953BD552-4B04-4CFD-ADB5-175BCCD6...
Do you really need them?
In the attached drawing I deleted them all with menu Tools -> Parametric ->Delete Constraints
Command: _DelConstraint
All constraints will be removed from selected objects…
Select objects: all
75075 found
Select objects:
2268 constraint(s) removed
I think they were created because you have Infer Constraints turned ON.
Check CONSTRAINTINFER system variable and set it to 0 (zero) if you don't need constraints. You may accidentally turned it ON with a button on Status Bar:
So be careful with it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you,
I checking it.
one more important information, I work on Mac.
How I do it on mac?
0 Me gusta
maxim_k
I gave you instructions specifically for the Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you very much.
the problem seems to be solved.
Thank you.
0 Me gusta
No aplicable
 It worked, thanks for the suggestion :símbolo_del_pulgar_hacia_arriba:
0 Me gusta
