SUBTRACT: objects: 1 found, No objects found
Hello. I'm trying to subtract an object from a block object. Here is my process:
SUBTRACT [Enter/return]
"Select solids, surfaces, and regions to subtract from .."
*clicks on object to subract from*
"Select objects: 1 found"
[Enter/return]
"Select objects:
No solids, surfaces, or regions selected."
Here is the LIST command data from the first object/ the one i'm trying to subtract from:
Select objects:
BLOCK REFERENCE Layer: "0"
Space: Model space
Handle = a9ef
Block Name: "FENDER"
at point, X= 0.0000 Y= 0.0000 Z= -2.0000
X scale factor: 0.8000
Y scale factor: 1.0000
Ive attached a video.
pendean
Community Legend
Community Legend
"No solids, surfaces, or regions selected" is the key problem here: your selection is not one of those object types, hat includes blocks (a block of a solid is a block object type, it is no longer a solid).
Do you understand what I typed? Let us know if not.
Yes, completely understood. How would I convert this into a manipulative
object?
maxim_k
>>>>How would I convert this into a manipulative object?
Explode it with EXPLODE command:
https://help.autodesk.com/view/ACDMAC/2018/ENU/index.html?guid=GUID-B38FD713-AD2F-4D9E-AD68-60E3F7E3...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
