Strange xref behaviour
PeterHarding7326
Message 1 of 11
PeterHarding7326
I have a master building drawing OVL1 that has a number of event spaces on it in a large exhibition centre
there are two contractors that collaborate in each space. Party, Breakout, Networking, Plenary
HTH - a technical supplier
TBP - a event designer
we have an overall master drg is made showing all the drawings together to create a composite drawing
where
hth  - party, breakout, networking and plenary individual drawings
and
TBP -  party, breakout, networking and plenary individual drawings
and
OVL1 building drawing are all xrefed in
To be able to work on each area the
HTH contractor would create a drawing for each area such as party
In HTH party drawing
i have a HTH contractors drawing entities and
Overlay xref of OVL1 (clipped with a rectangle window)
TBP Party as an overlay xref
In TBP party drawing
i have a TBP contractors drawing entities and
HTH Party as an overlay xref
HTH party dwg works as expected, but when i open up but TBP party dwg when i zoom extents, it zooms to a blank space, when i click the OVL xref it shows the correct clipframe and a phantom invisble but now highlighted clip frame that is causing the zoom into open space.
how can i fix this!
tried everything i can think of
Replies (10)
Message 2 of 11
PeterHarding7326
This illustrates the problem, interestingly one xref the furthest right at the top doesnt have the problemthe phantom blue squares from the highlighted refsthe phantom blue squares from the highlighted refs
Message 3 of 11
PeterHarding7326
interestingly the one that works doesnt have the TBP-OVL master build xref clipped in it
Message 4 of 11
PeterHarding7326
As soon as you clip that master drawing then the problem is evident
Message 5 of 11
maxim_k
Hi Peter,
Have you tried to use AUDIT command to find and fix errors in the problem drawing?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 11
PeterHarding7326
Yes I have done that and none found
P
Message 7 of 11
maxim_k
Can you share the whole set of drawings here?
Or you can send it to my mail: [email protected]
I'll look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 11
PeterHarding7326
It seems to be connected with clipping the master building overlay In HTH – PARTY drawing
In HTH – PARTY
There is
TBP-OVL2 as overlay clipped
TBP-PARTY as overlay clipped
Ie
In Overall master summit 2019
TBP-OVL2 is an attached xref unclipped
HTH – PARTY is an attached xref unclipped
If you clip the TBP-OVL2 in HTH – PARTY then it shows a phantom clip border when in the SUMMIT Master
Have sent a dropbox link to your email with all the drawings. - let me know if you dont get it
Message 9 of 11
maxim_k
Got it, looking into it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 11
maxim_k
I sent dropbox link ti edited set of drawings to your email.
What I have done:
I changed the type of xrefs in the all drawings in the set from Overlay to Attachment.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 11
PeterHarding7326
Maxim,
Thanks for looking at this, so is this a bug and switching to attached from overlay fixes it, because it would seem that overlay is the right way to go here?
or am I missing something.
Best
Pete.
