STB Plot Styles do not display (Mac)
I have seen a few posts about this issue but I think this one is slightly different.
I am trying to use an STB which is a modified version of the Autodesk supplied Autodesk-Mono.stb, where all the screening styles are set to Grayscale instead of BLACK.
If I set my drawing to use the unmodified Autodesk-Mono.stb, all the styles in the STB file are available in the menu drop-downs wherever I look (Layers Palette, Properties palette etc.). If I switch to my Autodesk-Grayscale.stb, only Normal, ByBlock and ByLayer style are available.
I have used this STB file before successfully, but have upgraded to Autocad LT 2017, perhaps this is related.
if anyone would care to try out my STB file, it is attached. I have recreated it from scratch, and the problem persisted so I don't think it is a file corruption issue. (I have add .TXT to the file extension to .TXT so that it can be uploaded, it will need to be removed so that it is just .stb before use).
thanks
