Anuncios
Status bar small
PMiddelkoop
Status bar small
PMiddelkoop
I've the some problem with my status bar, it is half the hight it should be. Tried the reset pallets trick but this opens a new session of AutoCAD with the same proplem. I'm using AutoCADLT 2015 on a MacBook Pro (Retina, 15 inch, medio 2014). I already searched the AutoCAD for Mac Forum with no luck.
Is there any solution to this problem i've missed?
Kind regards,
Patrick Middelkoop
0 Me gusta
Responder
Soluciones aceptadas (1)
1.679 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Solución aceptada
If "Reset Palettes" doesn't work for you, you may also try to Reset Application options, but be aware - that will reset all settings to their default values.
Before trying resetting Application options I'd suggest you to check icon sizes in AutoCAD options - if you changed them (increased their size), try at first set the default size, than reset palettes again.
Another way to try is to trash "Profile.aws" file, which is in
"/Users/YOUR_USER_NAME/Library/Application Support/Autodesk/roaming/AutoCAD LT 2015 Standalone/R20.0/enu/Support/"
folder. YOUR_USER_NAME is your short user name on Mac.You need to QUIT AutoCAD before trashing this file.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
PMiddelkoop
Thanx Maxim,
I changed te the icon sizes in the AutoCAD preferences to big and then changed them back to normal. Now my status bar is back to it's normal size.
I hope they stay this size, but now I know, if they change again, what to do.
Thanx again.
Patrick Middelkoop
0 Me gusta
