Startup Error
Startup Error
No aplicable
Hi  Just installed mac 2016  Autocad and activated but when trying to start autocad get the following error
The directory may be locked by another process or have been set Read Only.
Directory: '/Users/administrator'
Directory is not locked and ran following commands in Terminal:
chmod -R +w $HOME
Still no luck
0 Me gusta
Responder
Soluciones aceptadas (1)
872 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Welcome to Autodesk Forums!
You can try to create new account on your Mac with Admin privileges, login to it and launch AutoCAD. Does it start now?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thanx for the tip.
I installed under my Administrator Account on my Mac.
Also tried upgrading to El Capitan (hence the delay in getting back) as thought AutoCAD MAC 2016 may require this upgrade.
Still no joy
0 Me gusta
maxim_k
Solución aceptada
I asked you to create new user account. Have you tried this?
Have you tried this solution:
http://upandready.typepad.com/up_and_ready/2012/09/autocad-lt-alert-the-directory-may-be-locked-by-a...
Plus there is another topic about such issue :
https://forums.autodesk.com/t5/autocad-for-mac-general/can-t-open-autocad-2012-on-my-macbook-pro/td-...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
OK great, that worked.   My error was that I was looking at the shared folder and locked tabs for the folder and not the permissions at the bottom of the screen.   Autocad booted up once I enabled R&W access for all users, not just the adminstrator.
Thank you very much for the help.
0 Me gusta
