Splitting modelspace into multiple viewports
sehyun0701
sehyun0701
Hi I'm using autocad LT for mac
I have several drawing files open and need to check back and forth between them
is there a way to split modelspace into several viewports so I can see them all at once?
maxim_k
Hi @sehyun0701 ,
You can split Modelspace layout into several viewports with -VPORTS command, but they will show the contents of the file in which you use -VPORTS command. In order to see the contents of other drawings, you can attach them to the "master" drawing as Xrefs.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
