slow auto cad
slow auto cad
slow auto cad
Please can someone help.. For some reason this is so slow i cant even work on it it is that slow.
maxim_k
Welcome to Autodesk Forums!
Try attached drawing.
I deleted all parametric constraints from your drawing with DELCONSTRAINT command
Command: _DelConstraint
All constraints will be removed from selected objects…
Select objects: all
21683 found
Select objects:
1020 constraint(s) removed
Plus I changed Wireframe Visual Style to 2D Wireframe.
Avoid to use parametric constraints if you really don't need them. Check also that Infer Constraints mode is turned OFF - look for the button on the Status Bar.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi there again,
2nd time you've come to my rescue :D.
Ill let you know how it goes.
Alex
Thank you so much
Emmsleys
Alex,
Checking in on this thread, did @ maxim_k post help resolve your issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks.
Sarah Emmsley
Technical Support Specialist
