Anuncios
Shortcut To Reset Model Space to a Single Viewport
mitchelllance
mitchelllance
is there a shortcut to maximize a viewport in model space and then switch back to single viewport. in other words, is there a shortcut to maximize and restore the viewport in model space on mac. thank you.
0 Me gusta
Responder
Soluciones aceptadas (1)
667 Vistas
5 Respuestas
Respuestas (5)
maxim_k
Hi @mitchelllance ,
If I understand you correctly, you are working on Model tab and have two or more tiled viewports on it.
In this case you can switch to a single viewport by double clicking on "+" in the upper-left corner of the viewport:
If you need to maximize viewport on Layout tab, then you can double-click on its border, to minimize it - double-click on the wide light blue border around maximised viewport:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
mitchelllance
you are correct about my issue when working in model space. but i’m wondering if there is a keyboard shortcut that is faster than clicking on the “+”? if no shortcut exists, can i create one with the aliases in preferences and what is the command to create the alias. thanks.
0 Me gusta
maxim_k
@mitchelllance wrote:
..... if no shortcut exists, can i create one with the aliases in preferences and what is the command to create the alias. thanks.
Yes, it doesn't exist and you can create one.
At first create new Command macro:
Now you can assign this new macro to a shortcut of your choice:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
mitchelllance
i'm having trouble with the macro. i'm using autocad 2020 so no option for shortcuts in CUI, only aliases.
my first issue is that the macro is not working. i copied your instructions, and i put this new command in the menu bar to test, but it is not working?
my second issue is how to add the command to aliases. once i click the "+" to add, it does not appear in the command search. thanks for your help.
0 Me gusta
maxim_k
Solución aceptada
Hi @mitchelllance ,
Looks like you missed a space between _-vports and_T. The macro should looks like:
^C^C_-vports _T
don't forget to add space after _T too.
Yes, you cannot use alias for custom macro.
It is not possible to create shortcuts in 2020 version officially. But you can add custom command to the menu and then use macOS System Preferences to create shortcut for it.
EDIT:
You can read more about creating shortcuts in AutoCAD for Mac prior to 2023 version here:
https://macacad.wordpress.com/2010/10/28/creating-shortcuts-for-custom-commands-in-autocad-for-mac/
https://macacad.wordpress.com/2010/12/20/edit-and-create-shortcuts-in-autocad-for-mac-yes-it-is-poss...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
