AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Shift+mouse scroll on AutoCAD Mac
1 REPLY 1
2596 Views, 1 Reply
Hello, i'm working on AutoCAD 2013 on my Mac, and since some time I'm experiencing this annoying feature : i'm stretching somethin, than I want to deselect objects using the shift key, and it passes in 3D orbit mode. It's so frustrating and I found no place to disable this feature. Anyway, I never use the 3D functions of AutoCAD so to turn it off for me would be great.
I found the same subject discussed on AutoCAD on Windows, where the mouse shortcuts can be modified in the CUI, but on Mac it doesn't seem to be possible...
Thanks !
Thanks !
Tags (3)
1 REPLY 1
maxim_k
maxim_k
It seems that in AC for Mac the options for mouse behavior with Shift and Cmd keys are not customizable, even if you will try to "drill" inside .CUI files with text editor, there is no MouseButtonRoot.cui file in AutoCAD for Mac (in this file settings for mouse behavior stored in PC version of AutoCAD)
I also have the same troubles from time to time and I mostly use Apple Magic mouse on my Mac.
The case is that when you click "left" mouse button on Magic mouse with Shift key pressed, sometimes you accidentally "slide" with finger on mouse touch surface and System conceder this as scrolling with mouse, and in AutoCAD fro Mac scrolling with Shift turns on 3DOrbit transparent command.
What mouse do you use on your Mac?
Is it Apple Magic Mouse? or something other?
If it is Magic mouse you can use the trick with MagicPrefs application (do you use this application?)
Go to MagicMouse Preferences, click on "Configure Scrolling" button at the bottom right of dialog, you will get such window:
By default Scrolling area is very large - all Magic Mouse surface.
You can reduce this area and move it to the right side:
then when you click on the "left" button with Shift pressed in AutoCAD, the scrolling effect will not be enabled and you will nit get 3DOrbit by accident.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
