Shift-Deselect not working with Stretch - ACAD LT MAC 2015 OS X El Capitan
sapote
sapote
Stretch>Select>Shift-Click>Deselect is not working.
It was working with previous versions of both and now it is not. What has changed? I've tried changing system varibles; OSOPTIONS, SELECTIONCYCLING,...
It's enough getting used to new Magic Mouse 2 with ACAD (not having 3-button mouse), but now this?
Please help. And do not tell me to post to AutoCAD LT for MAC forum. There isn't one. I've clicked on those links and they lead me in circles to ACAD for MAC/General Discussions forums.
System:
AutoCAD LT MAC 2015 (J.51.M.453)
iMac17,1 27-inch 5K Retina Display Late 2015
OS X 10.11.1 El Capitan
0 Me gusta
Responder
1.145 Vistas
11 Respuestas
Respuestas (11)
maxim_k
Is it only for stretch? Or it doesn't work for other editing commands?
What setting do you have for PICKADD system variable?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
sapote
Unbelievable. I come back to it a few hours later and it's working. And then not 5 minutes after that it stops working while I'm trying other tools; Scale, Move, Copy,.. doesn't matter. Even selecting with cursor was working while Stretch was not and now that doesn't work either. Bizarre. Nothing has changed (system variables,..). The file has been open the whole time.
PICKADD = 2. No difference with 1 or 0. Also tried changing OSOPTIONS, SELECTCYCLE?,...
 So I think at least we can rule out system variables or something I forgot to check or uncheck. Again, this was working fine on old iMac with same OS X. Everything was the same except for the iMac's.
Graphics card?
iMac (Retina 5K, 27-inch, Late 2015)
3.2 GHz Intel Core i5
24 GB 1867 MHz DDR3
AMD Radeon R9 M380 2048 MB
OS X 10.11.1 (15B42)
0 Me gusta
maxim_k
>>>Graphics card?
Could be... Not sure.
Have you tried to reset AutoCAD? If no, you can try, but I'd recommend you to backup
~/Library/Application Support/Autodesk/roaming/AutoCAD 2015
and
~/Library/Application Support/Autodesk/local/AutoCAD 2015
folders in order to be able to revert everything back, or at least to restore your customisations for commands and menus from
~/Library/Application Support/Autodesk/roaming/AutoCAD 2015/R20.0/enu/Support
Plot Styles from
~/Library/Application Support/Autodesk/roaming/AutoCAD 2015/R20.0/enu/Plotters/Plot Styles
Templates from
~/Library/Application Support/Autodesk/local/AutoCAD 2015/R20.0/enu/Template
and Content libraries from
~/Library/Application Support/Autodesk/local/AutoCAD 2015/R20.0/enu/Support/ToolPalette
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
sapote
 It's working again... And I did not reset ACAD, nor make any changes with system variables or other settings.
 I just started up the iMac this morning (after being shut down overnight). Opened AutoCAD LT 2015. Opened same file as before and began using tools; Stretch, Scale, Copy,..etc., even select with cursor. Shift-Click deselect worked every time. Amazing, how it works... and then it doesn't work.. and then it works again.
0 Me gusta
sapote
Does anyone have a thought as to why AutoCAD LT 2015 for Mac is bahaving like this?
0 Me gusta
maxim_k
Please verify that system variable PICKADD=2
You may also try to turn off "lasso selection" feature by setting PICKAUTO=1 or PICKAUTO=2
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
sapote
PICKADD was 2, but that's irrelevant because Shift-Deselect would work and then not work w/o any changes to settings.
In the meantime, I've reset AutoCAD LT Mac 2015. It's been working, but it could change again.
0 Me gusta
sapote
It's not working again..  because I unchecked "Use Shift key to add to selection" - the way I prefer to use Selection Modes.
I posted too soon. It was only working with normal select/deselect. It's not working with Stretch.
0 Me gusta
sapote
Still happening 5 months later.... with AutoCAD LT 2016 for MAC. Same iMac / OS X 10.11.4.
PICKADD = 2
Tried changing it to 1 then back to 2, no effect. Minus "-" sign shows above cursor selection box but Shift-Click will not deselect lines/objects. This is very annoying how it'll suddenly start acting up.
0 Me gusta
jamncar
Community Visitor
Community Visitor
It has to do with the Raster Tools Mouse Settings..I had this problem as well and found a solution elsewhere.
https://blogs.rand.com/support/2015/04/autocad-hold-down-shift-to-deselect-does-not-work.html
This corrected my issue of not being able to deselect when trying to stretch. Under raster design options, user preferences, mouse settings-uncheck the "Shift+Left click image select". You can find this under the Raster Tools tab in the ribbon and then click the diagonal down arrow in the lower right corner of the "Insert & Write" tool and that will open the AutoCAD Raster Design Options menu.
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
Hi James,
You are posting in AutoCAD for Mac Forum, but there is no Raster Design on Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
